Renesas R8C/L36M microcontrollers lineup
Renesas R8C/L36M
Product Overview:
The Renesas R8C/L36M is based on the R8C CPU Core. Maximum operating frequency is 20MHz. A Flash Memory Version is available. Internal Flash Memory is programmable on a single power source.
Key Features:
  • 5 MHz operation at 1.8 V supply voltage, and 20 MHz operation from 2.7 V available
  • 8-bit Multifunction Timer with 8-bit prescaler (Timer RA and RB): 2
  • 16-bit Input Capture/Output Compare Timer (Timer RC, RD, RG): 4
  • 8-bit Real-Time Clock Timer with compare match function (Timer RE): 1
  • UART/Clock Synchronous Serial Interface: 3 channels
  • I2C-bus Interface/Synchronous Serial Communication Unit: 1 channel
  • LIN Module: 1 channel (Timer RA, UART0)
  • 10-bit A/D Converter: 12 channels
  • 8-bit D/A Converter: 2
  • Comparator: 4
  • LCD Drive Control Circuit
    • Bias: 1/2, 1/3, 1/4
    • Duty: Static, 1/2, 1/3, 1/4, 1/8
    • Common output: Max. 8 pins
    • Segment output: Max. 32 pins (when four common output pins are selected)
    • Voltage multiplier and dedicated regulator integrated.
  • DTC (Data Transfer Controller): 1 channel
  • Watchdog Timer
  • Clock Generating Circuits: XIN Clock Oscillation Circuit, On-chip Oscillator (High/Low Speed), XCIN Clock Oscillation Circuit
  • Low Power Consumption Modes
    • Standard Operating Mode (Clock (High/Low speed), On-chip Oscillator (High/Low speed))
    • Wait Mode, Stop mode, Power-off Mode
  • Oscillation Stop Detection
  • Voltage Detection Circuit
  • Power-On Reset Circuit
  • I/O Ports: 52 (incl. LED drive ports)
  • External Interrupt Pins: 12
  • Data Flash with Background Operation (BGO) function: 4KB
R8C/L36M Block diagram
Renesas: R8C/L36M block diagram
Click to enlarge
Key Applications:
Electronic Household Appliances, Office Equipment, Audio Equipment, Consumer Products
Product Lineup:
R8C/L36M Group
Part No. Flash RAM Operating Frequency /
Supply Voltage
Package
R5F2L367MDFA 48K + 4K 6K 20MHz / 2.7V – 5.5V
5MHz / 1.8V – 5.5V
LQFP
R5F2L367MDFP
R5F2L367MNFA
R5F2L367MNFP
R5F2L368MDFA 64K + 4K 8K
R5F2L368MDFP
R5F2L368MNFA
R5F2L368MNFP
R5F2L36AMDFA 96K + 4K 10K
R5F2L36AMDFP
R5F2L36AMNFA
R5F2L36AMNFP
R5F2L36CMDFA 128K + 4K
R5F2L36CMDFP
R5F2L36CMNFA
R5F2L36CMNFP
renesas.eu
