Renesas R8C/3NT Group Overview
Renesas R5F213N7TNBX R5F213N8TNBX R5F213NATNBX R5F213NCTNBX
Overview
The touch key microcontrollers (MCUs) of the R8C/3NT Group from Renesas Electronics are devices incorporating an electrostatic capacitive touch detector into the R8C/3x Series.
Renesas Electronics - R8C/3NT
By integrating on a single chip a touch sensor IC for touch detection and a microcontroller for controlling the system based on the signals received, the R8C/3NT Group specifically meets the following five customer needs:
  • More compact system size, and further smaller WPP package (3 mm × 3mm) for smaller devices
  • System control via I/O ports
  • Touch key connection via touch detection input pins (5-input)
  • Reduced power consumption
  • Improved noise tolerance
R8C/3NT Block Diagram
Renesas: Блок-схема микроконтроллеров группы R8C/3NT
Click to enlarge
Specifications
  • CPU core: R8C 16-bit CPU core
  • Minimum instruction execution time: 50 nsec (f(Xin) = 20 MHz)
  • Supply voltage: 2.7 to 5.5 V/Max. 20 MHz, 1.8 to 5.5 V/Max. 5 MHz
  • DTC (Data transfer controller): 1 ch
  • ROM/RAM: 48 KB/4 KB, 64 KB/6 KB, 96 KB/8 KB, 128 KB/10 KB (RAM: 0.5 KB for touch detection)
  • Data flash: 1 KB × 4 blocks (Touch setting values can be stored.), with background operation (BGO) function
  • Clock generation circuits: 4 circuits
    • XIN-XOUT main clock (oscillation stop detection circuit included)
    • XCIN-XCOUT sub clock
    • High-speed on-chip oscillator (40 MHz Typ.)
    • Low-speed on-chip oscillator (125 kHz Typ.)
  • Voltage detection circuit (LVD): 3 circuits (detection levels selectable)
  • Power-on reset (POR): Yes
  • Watchdog timer: 1 ch (supports hardware reset)
  • Multifunction timer: 3 ch
    • 8-bit timer 2 ch (Timer RA, Timer RB)
    • 16-bit timer 1 ch (Timer RC)
  • Real-time clock timer: 1ch
    • 8-bit timer 1 ch
  • Serial interface: 3 ch
    • Clock synchronous/UART0, UART1, UART2
  • I2C/SSU: 4 circuits
  • A/D converter: 10-bit x 12 ch
  • Touch detector (SCU): 5-input (shared with I/O ports) (Reduces power consumption by allowing touch detection in wait mode.)
  • I/O ports: Input/Output: 43, Input only: 1 (Large-current drive capacity is provided. Variable input threshold values: 3 values)
  • Package: 48-pin WPP (3 mm × 3 mm)
Product Lineup:
R8C/3NT Group
Part No
ROM
RAM
Operating Frequency /
Supply Voltage
Package
R5F213N7TNBX 48K + 4K 4K 20MHz/2.7 to 5.5V,
5MHz/1.8 to 5.5V
48-pin WPP
R5F213N8TNBX 64K + 4K 6K
R5F213NATNBX 96K + 4K 8K
R5F213NCTNBX 128K + 4K 10K
renesas.eu
