Auto-Audio
Bad Prescript
Music
The BER tester uses …
The BER tester uses a signal generator with OOK (on/off-key) modulation
Israel Schneiderman
Simple setup tests bit-error rate
Figure 2
7 Kb
Figure 1. This timing diagram illustrates the operating principles of a simple BER tester
Figure 2. The BER tester uses a signal generator with OOK (on/off-key) modulation
Figure 3. The simple BER tester uses an adjustable phase shifter and a differentiator
