Ultra Small (0.75mm × 0.95mm × h0.4mm), High Precision (±0.8%) Voltage Detector XC6126 Series
Torex XC6126
Torex has developed an ultra small  high-precision voltage detector.
The XC6126 Series of high-precision voltage detectors are housed in the ultra-small USPN-4B02 package (0.75 × 0.95 × h0.4mm) and have a low quiescent current of 0.6μA (at detection VDF=1.8V, VIN=1.62V) (TYP.). The small package size makes a major contribution to space-saving circuit design.
Torex - XC6126
The operating voltage range is 0.7V to 6.0V. The detection voltage range is 1.5V to 5.5V, and the detection voltage can be set in steps of 0.1V within this range. N-ch open drain or CMOS output can be selected for the output format. Ideal for reset of microcomputers and logic circuits, battery check, charge detection, and system power-on reset.
The ultra small USPN-4B02 and SSOT-24 packages are available for selection as appropriate for the application. This is also an environment-friendly product that complies with the RoHS Directive of the EU and is Pb-free.
XC6126 Series Features
  • Ultra-small 0.75 × 0.95 × h0.4mm package
  • High-precision ±0.8% (Ta=25°C)
  • Low quiescent current of 0.6μA typical (at detection VDF =1.8V, VIN =1.62V)
  • Ideal for reset of microcomputers and logic circuits, battery check, charge detection, and system power-on reset
  • N-ch open drain or CMOS output can be selected for the output format.
torex.co.jp
