International Rectifier introduced the GH Series of radiation hardened (RAD-Hard™) DC-DC converters. The new 50 W devices are designed to maximize efficiency for onboard spacecraft applications requiring long mission life up to 15 years.
The GH Series of devices is suitable for designs using new digital signal processors and FPGA technologies that require a supply voltage as low as 1.0 V. Key features include 18 V to 40 V input range, total ionization dose (TID) of over 100 krad (Si), single event effect (SEE) (Heavy Ions) with rated LET greater than 82 MeV.cm²/mg, internal EMI filter complying with most major satellite power buses, and a weight of less than 110 g.
The GH Series was developed using a proven space-level design methodology that includes selection of established reliable components and fully de-rated to the requirements of MIL-STD-1547. The devices feature magnetically coupled feedback to insure robust operation under the intended radiation environments.
The output models range from 1.0 V to 5.0 V with current rating of up to 20 A and high efficiency up to 87 percent. Output is adjustable with an external resistor for a precise output voltage setting with the adjustment range of ±10% of the rated output voltage. Other key features include remote sense compensation, remote output on/off control via Inhibit pin, input under-voltage protection with under-voltage lockout (UVLO), and synchronization for applications with multiple converters.
![]() Click to enlarge |
Block Diagram - Single Output |
Specifications
Part Number
Output Voltage
(V) |
Output Current
(A) |
Output Power
(W) |
Typical Efficiency
GH2801S
1.0
20.0
20
73
GH2801R5S
1.5
20.0
30
75
GH2801R8S
1.8
20.0
36
78
GH2802R5S
2.5
20.0
50
84
GH2803R3S
3.3
15.2
50
85
GH2805S
5.0
10.0
50
87
Availability and Pricing
Pricing for the GH2803R3S begins at US $17,500 each for 5-10 unit quantities. Production orders are available immediately. Prices are subject to change. This product is subject to U.S. export control laws and regulations.
