BGS 12AL7-6 - ultrasmall SPDT RF switch with low insertion loss and no external components required
Infineon BGS12AL7-6
The Infineon's BGS 12AL7-6 is a general-purpose, single-pole, double-throw (SPDT) RF-CMOS switch designed for power levels up to 20 dBm. Manufactured using a unique variant of the industry-standard RF-CMOS technology, this switch does not require external DC blocking capacitors, and the control logic is fully integrated on a single die. With an insertion loss of only 0.35 dB at 1.0 GHz, the BGS 12AL7-6 provides the same level of performance as GaAs switches, while requiring less printed circuit board area and delivering a better cost position. All interfaces are protected against ESD up to at least 1.0 kV HBM (human body model). The BGS 12AL7-6 comes in the new, ultrasmall TSLP-7-6 package measuring only 1.4 × 1.26 × 0.39 mm3.
Infineon - BGS12AL7-6
Features
  • Cost and space savings due to a reduction in external components
  • On-chip control logic with CMOS-compatible control voltage (1.4 V…2.8 V)
  • Relaxed filtering requirements due to low harmonic levels
  • Low insertion loss of 0.35 dB at 1 GHz
  • Improved yield due to fewer ESD failures during production
  • Greater reliability than mechanical switches
Applications
  • Cellphones
  • Digital TV Tuner
  • FM radios
  • Game consoles
  • Data cards
  • RF modules
BGS12AL7 block diagram
infineon-designlink.com
