Analog Devices' RMS-to-DC Converter Ensures Accuracy and Best-in-Class Dynamic Range
Analog Devices AD8436
Analog Devices unveiled an integrated true RMS-to-DC converter that offers a best-in-class 100 µV to 3 V of usable dynamic range and the ability to measure extremely low signal levels with high accuracy and no drop in settling time.
Analog Devices - AD8436
The AD8436 precision monolithic true RMS-to-DC converter features AC conversion accuracy to better than ± 0.5 percent. Uniform settling for widely variant input values enables consistent conversion rates with results displayed promptly for near-zero and high-level AC inputs. The AD8436 is immune to temperature, crest factor and supply voltage variations. Zero DC offset voltages at the converter output simplify calibration. This performance is packed into a compact 4 mm x 4 mm package integrated with a FET input and precision DC buffer amplifiers and consumes only 300 uA of power. The AD8436 is a good choice for remote, portable battery-powered instrumentation, energy and automotive applications where limited board space and outdoor environments are considerations.
RMS (root mean square) is a fundamental measurement of the magnitude of an AC and DC signal and is a better measure of the power in a signal than simple averaging. RMS-to-DC converters are used in applications where precise, low power measurement of AC/DC signals is the prime objective. The AD8436 system-on-a-chip design computes the precise DC equivalent of the RMS value and provides a level of linearity and accuracy across the entire input range that enables engineers to design systems with 90 dB of dynamic range.
The AD8436 extends the crest-factor to 10 – approximately double the current industry-standard digital solution – with minimal loss of accuracy. It is particularly useful for high transit signals and can be used in designs currently using ADI’s low-power, true RMS-to-DC converters such as the AD736 and AD737 with improved performances. The device is laser trimmed and characterized at 300-mV RMS input and comes with dual and single power supplies. The AD8436 is the first RMS-to-DC converter specified to operate in the extended industrial temperature range of -40°C to 125°C. It is also available in a 0°C to 70°C temperature range version.
AD8436 Precision, Low Power, Monolithic True RMS-to-DC Converter Key Features:
  • Instantly computes true RMS value
  • Fast and constant settling time at all input levels
  • Wide usable dynamic range: 100 uV RMS to 3 VRMS (8.5 V p-p) full-scale
  • Input frequency range: 65 kHz for additional 1 percent error
  • Low power: 300 µA typical at ±2.4 V
  • Accuracy: ±10 μV ± 0.5 percent of reading max
  • System-on-a-chip includes FET input buffer with precision gain setting resistors, output buffer
  • Supply range:
    • Dual: +/-2.4 V to +/-18 V
    • Single: 4.8 V to 36 V
analog.com
