ADA4096-2: 30V, Micropower, Overvoltage Protection, RRIO Op Amp
Analog Devices ADA4096
Product Description
The ADA4096 operational amplifier features micropower operation and input and output ranges. The extremely low power requirements and guaranteed operation from 3 V to 30 V make these amplifiers perfectly suited to monitor battery usage and to control battery charging. Their dynamic performance, including 27 nV/√Hz voltage noise density, recommends them for battery-powered audio applications. Capacitive loads to 200 pF are handled without oscillation.
Analog Devices - ADA4096
The ADA4096-2 has overvoltage protection inputs and diodes that allow the voltage input to extend 32 V above and below the supply rails, making this device ideal for robust industrial applications.
The ADA4096-2 features a unique input stage that allows the input voltage to exceed either supply safely without any phase reversal or latch-up; this is called overvoltage protection, or OVP.
The dual ADA4096-2 is available in 8-lead LFCSP (2 mm × 2 mm) and 8-lead MSOP packages. The ADA409x family is specified over the extended industrial temperature range (−40°C to +125°C) and is part of the growing selection of 30 V, low power op amps from Analog Devices, Inc.
Features
  • Input overvoltage protection, 32 V above and below the supply rails
  • Rail-to-rail input and output swing
  • Low power: 60 μA per amplifier typical
  • Unity Gain Bandwidth:
    •  800 kHz typ @ VSY = ±15 V
    • 550 kHz typ @ VSY = ±5 V
    • 465 kHz typ @ VSY = ±1.5 V
Specifications
  • Single-supply operation: 3 V to 30 V
  • Low offset voltage: 300 μV maximum
  • High open-loop gain: 120 dB typical
  • Unity-gain stable
  • No phase reversal
  • Qualified for automotive applications
Applications
  • Battery monitoring
  • Sensor conditioners
  • Portable power supply control
  • Portable instrumentation
analog.com
