Spansion Introduces Fastest Serial Flash Memory
Spansion FL-S
Spansion Inc. announced the industry's fastest serial Flash memory, the Spansion® FL-S NOR Flash memory family at 65nm. The product family has over 20% faster double data rate (DDR) read speeds and three times the programming speed over competing serial Flash solutions.
Spansion FL-S NOR Flash memory
The Spansion FL-S delivers leading performance, automotive grade temperature ranges and in some applications, eliminates the need for DRAM.
Engineers are increasingly demanding these attributes for improving the user experience and designing innovative, graphic-rich, stylish designs in next generation electronics. The product family is available from 128 Mb (megabit) to 1 Gb (gigabit).
Specific applications that can benefit from the Spansion FL-S product family include the following:
  • Automotive: Instrument clusters and infotainment systems, which rely on 3D graphic engines for displaying real-time driver information and demand high reliability, real-time fast rendering and lower pin counts. These capabilities are required for giving consumers stylish designs with improved graphics and an instant on experience with their digital dashboards.
  • Consumer: Home gateways, digital TVs, set top boxes and printers, which require smaller packages in a high-density serial interface and advanced security features to protect content, allowing manufacturers to give their end consumers a secure and instant-on experience.
  • Smart meters: High reliability performance in a cost effective platform for the growing amounts of Flash memory code needed to monitor energy usage.
  • WiMax systems: Increasingly require smaller packages such as BGA with high reliability.
Serial Flash memory (SPI) transmits and receives data in one, two, four or eight bits per clock cycle from the same device, enabling backwards compatibility and faster speeds. Most solutions today use one, two or four bits, whereas Spansion's FL-S products expand the bits per clock cycle to eight. Spansion's serial product portfolio is now available from 4 Mb to 1 Gb and complements Spansion's parallel NOR Flash memory family.
Executive Quotes
"Serial Flash memory is estimated to grow at a CAGR of approximately 19 percent through 2015 as next generation electronics require real-time processing, advanced security, 3D graphics and smaller form factors in consumer, automotive and industrial applications," said Alan Niebel, CEO of Web-Feet Research. "Spansion is well positioned to address these application needs due to its leadership in the embedded NOR market and the high-performance of its Spansion FL-S product."
"Customer demand for serial interfaces is transitioning from low density and low cost solutions to higher density offerings with more advanced performance," said Robert France, vice president of strategic and product marketing at Spansion. "With our newest Spansion FL-S product family, we deliver advanced performance and address specific application requirements, which will enable our customers to design innovative next generation electronics."
Key Facts/Performance Metrics of the Spansion FL-S family:
  • The 128 and 256 Mb Spansion FL-S products are sampling now and will start production in October. The 512 Mb density will be in production in Q4 with the 1 Gb density in Q2 2012.
  • Industrial and Automotive In-Cabin temperature support (-40C to +85C/+105C)
  • 20% faster read performance with up to 66 MB/s for faster execute in place (XiP) operation, surpassing competing solutions by over 20%.
  • Up to 1.5 MB/s write speed that is three times faster than current SPI solutions in the market, increasing manufacturing throughput and lowering overall costs.
  • Three times faster chip erase coupled with the three times faster programming speed dramatically improves chip re-programming time during manufacturing.
  • Industry-standard form-factors via Spansion's Universal Footprint
    • 16-pin SO (300 mil)
    • 8-pin SO (208 mil planned for 128 Mb)
    • 8-lead WSON 6x8 (128 Mb and 256 Mb densities only)
    • 24-ball BGA 6x8
  • The low pin count simplifies board layout, lowers cost, and reduces the form factor of many embedded designs, reducing to eight pins for a 128Mb SPI Flash device.
  • Expanded security options protect customer IP through 1kByte one-time programmable (OTP) region, individual sector protection, and hardware and software data protection. Unique 128 bit tracking ID for system authentication and additional security.
  • Vio range of 1.65V - 3.6V, Vcc range of 2.7V-3.6V
  • Common Flash Interface (CFI) data for configuration information
  • Industry-standard 3 Byte addressing for 128 Mb and extended 32-bit addressing (4 Bytes) for 256Mb and higher densities.
  • Spansion FFS: Customized software drivers and Flash file system software available at no additional cost.
