TLF50281: New 500mA Buck Converter with Low Current Consumption and High Switching Frequency
Infineon TLF50281
The new Infineon's TLF50281 is a 500mA buck converter with an output voltage of 5V (±2%) and a low quiescent current of 45µA. Thanks to a nominal switching frequency of 2.2MHz, small external components can be used, which in turn saves on PCB space. Integrated compensation and soft-start functions further reduce the number of external components. TLF50281 provides ENABLE and RESET capabilities with adjustable thresholds and a standard WATCHDOG. TLF50281 comes in a thermally enhanced, RoHS-compliant, SSOP-14 exposed pad package.
Infineon - TLF50281
Features
  • Output voltage: VQ = 5V (±2%)
  • Output current: IQ = 500mA
  • Low current consumption: Iq = 45µA
  • Integrated power transistor
  • High switching frequency (2.2MHz nominal) for small inductors
  • Synchronization input und frequency adjustment
  • Integrated compensation
  • Integrated soft-start function
  • Enable
  • Reset with adjustable RES threshold
  • Watchdog with adjustable WD timing
  • Automotive input voltage range up to 45V
  • Automotive-qualified and RoHS compliance
Applications
  • Body applications
  • Dashboards
  • Infotainment systems
