Microchip Introduces General-Purpose 8-bit PIC Microcontrollers With Next-Generation Digital and Analog Peripherals
Microchip PIC12F572 PIC12HV572
Microchip Technology Inc. announced from the Embedded World Conference in Germany a new family of 8-bit microcontrollers (MCUs) featuring next-generation analog and digital peripherals, making them ideal for general-purpose applications, as well as battery charging, LED lighting, ballast-control, power-conversion and system-control applications. The PIC12F(HV)752 MCUs feature an integrated Complementary Output Generator (COG) peripheral that provides non-overlapping, complementary waveforms for inputs such as comparators and Pulse Width Modulation (PWM) peripherals, while enabling dead-band control, auto shutdown, auto reset, phase control and blanking control. Additionally, the new MCUs feature 1.75 KB of self read-write program memory, 64B of RAM, an on-chip 10-bit ADC, Capture-Compare PWM modules, high-performance comparators (down to 40 ns response), and two 50 mA-capable I/O’s, enabling engineers to increase overall system capabilities and reduce costs.
Microchip PIC12F572, PIC12F(HV)572 MCUs
Engineers are constantly challenged to increase system performance and efficiency while reducing system costs, especially for newer LED-lighting and battery-charging applications. With their numerous on-chip, general-purpose and specialized peripherals, including the integrated COG, high performance comparators, 50 mA outputs for direct FET drive, the PIC12F(HV)752 MCUs meet these needs. The high-voltage variant in the family—the PIC12HV752 MCU—incorporates a shunt regulator that allows operation from 2V to an unspecified user-defined maximum voltage level, with less than 2 mA operation current. This high-voltage variant is ideal for cost-sensitive applications with high-voltage power rails. Additionally, the 4-channel, 10-bit ADC can be used to implement various sensors and mTouch™ sensing applications, including capacitive touch.
PIC12F572, PIC12HV572 Block Diagram
Development Support
The PIC12F(HV)752 MCUs are supported by Microchip’s standard suite of world-class development tools, including the MPLAB Integrated Development Environment (IDE), and the PICkit 3 (part # PG164130, $44.95), MPLAB REAL ICE (part # DV244005, $499.98), and MPLAB ICD 3 (part # DV164035, $189.99) debuggers/programmers. Engineers can also use Microchip’s HI-TECH C Compiler for PIC10/12/16 MCUs (part #s SW500010 and SW500005).
Pricing & Availability
The PIC12F752 MCU is available in a 8-pin 3 mm x 3 mm DFN package, as well as 8-pin PDIP and SOIC packages, for $0.56 each, in 10,000-unit quantities. The PIC12FHV752 is available in the same package options, for $0.60 each, in 10,000-unit quantities.
microchip.com
