Miniature Overvoltage Clamp from Diodes Incorporated Protects Portables
Diodes AP9060
Diodes Incorporated announced the introduction of an overvoltage clamp for the protection of power management ICs (PMIC) in portable applications. Provided in the small form factor 1.1mm × 1.4mm × 0.8mm W-DFN1114-3 package, the AP9060 is suitable for the latest generation battery-backed products including smart phones, tablets and ultra mobile PCs.
Diodes - AP9060
In addition, AP9060's use of a very low resistance p-channel MOSFET as the pass element ensures that any EMI issues are removed. This is achieved by avoiding noise generation on the input supply circuit normally associated with the charge pump of alternative n-channel MOSFET solutions.
Diodes - AP9060
Supporting a wide battery charger output range of 3V to 30V, the device will pass the voltage through to the PMIC only up to a safe clamp voltage limit, factory set at 11V. AP9060's feedback loop maintains the clamped output voltage level by backing off the drive to its p-channel MOSFET switch. With an ultra low bias current, the device also minimizes self-heating, thereby further increasing product reliability.
Diodes - AP9060
To increase its application flexibility, the AP9060 will also support reverse- current operation, allowing it to pass up to a maximum of 1A from the PMIC to a load connected to a USB port, therefore meeting the needs of USB On-The-Go (OTG) enabled products.
The AP9060 overvoltage clamp is a cost-effective alternative to larger and more complex combined overvoltage and overcurrent protection devices.
diodes.com
