Portwell announces the release of the FUDA Panel PC, featuring an Intel Atom dual-core processor D2550 1.86 GHz and an Intel NM10 chipset. The FUDA 5-wire resistive single touch screen and aluminum front bezel come standard. With its ultra-slim, lightweight, HDD tray and cable-less design, the FUDA Panel PC series is stylish and fan-free. Its flexible I/O board docking and COM port are selectable by BIOS. In addition to operating in a wide temperature and DC input ranges, the FUDA panel PCs are tested to IP65 water and dust resistant standards. The FUDA also comes equipped with APIs and EtherCAT support. With all these great features, the FUDA Panel PCs are ideal for Industrial Automation and the Food & Beverage Industries.
The New Standard for the Industrial Panel PC
While it has an attractive appearance and a stylish stainless steel or aluminum front bezel, the FUDA is also rugged and capable of operating in harsh environments with temperatures ranging from 0° to 50℃ and relative humidity of 5% to 95%. It is also resistant to vibrations up to 1G and shock up to 15G. The aluminum front bezel is IP65 certified as non-corrosive and can be customized to true flat overlay in order to conform to DIN EN 1672-2 and DIN 42115-2 standards, which permit the use of various cleaning solvents.
Versatile and Efficient
FUDA also offers a full HD video decoder to deliver greater graphical performance. Application Programming Interface (API) and EtherCAT support system integration of HMI and Cloud Computing efficiently, which enables quick and efficient changes or updates by way of the Internet when necessary. This cable-less model has an easily removable back cover and HDD tray. It comes equipped with an I/O board docking design and a Golden Finger connector with a RS-232/433/485 option via BIOS for the use of additional peripheral legacy devices. All of these features are packed within a 50mm thick console and designed with a choice of display sizes of 10.4" to 19".
Using Only the Best Components
Only the best components went into the FUDA design. The low power Intel Atom D2550 CPU with the Intel NM10 chipset platform utilizes only 40W when operating and 8W while in sleep mode. It also has a wide DC input of 12~24V (±20%) and an auto loss power-on feature in the event of power loss. Furthermore, with its aluminum tooling, heat sink and thermal pad, the FUDA is truly a fan-free, cool-running system.
