First Automotive MOSFET in DFN2020
NXP PMPB40SNA
NXP has just released its new PMPB40SNA, a 60 V, 40 mΩ N-channel automotive MOSFET in a compact 2 × 2 mm DFN2020MD-6 (SOT1220) package. The DFN2020MD-6 is an industry first, featuring 100% wettable and therefore solderable flanks (side pads). This makes soldering and inspection much easier and is aligned with the automotive optical solder inspection requirements! It is the perfect space-saving solution, about a factor 7 smaller compared to SO-8 and at the same time, delivers robust automotive qualified high performance.
NXP - PMPB40SNA
PMPB40SNA is one of 80 recently released MOSFETs in leadless 2 × 2 mm single, dual and 1 × 0.6 mm single DFN packages. The portfolio contains P- and N-Channel types from 12 to 60 V with very low RDSON values, automotive qualified and ESD protected types.
NXP - DFN2020MD-6
Features and benefits
  • 60 V, 40 mΩ single N-channel Trench MOSFET
  • Small and leadless ultra thin SMD plastic package DFN2020MD-6: 2 × 2 × 0.65 mm
  • Exposed drain pad for excellent thermal conduction leading to a power dissipation of 1.5 W
  • Tin-plated, 100% "wettable flanks" for optical solder inspection
  • AEC-Q101 qualified
Key applications
  • Relay driver
  • High-speed line driver
  • Low-side load switch
  • Switching circuits.
nxp.com
