Automotive AEC-Q101-Qualified, 40 V N-Channel TrenchFET® Power MOSFET With Low OnResistance Down to 1.1 mΩ and Continuous Drain Current of 200 A in 7-Pin D2PAK Packaging
Vishay SQM200N04-1m1L
Vishay Intertechnology announces a new AEC-Q101-qualified, 40 V n-channel TrenchFET power MOSFET. For automotive applications, the SQM200N04-1m1L is Vishay’s first power MOSFET to feature 7-pin D2PAK packaging, which is engineered for low on-resistance and high current ratings.
Vishay - SQM200N04
Product Benefits:
  • AEC-Q101 qualified
  • Low on-resistance of 1.1 mΩ max at 10 V and 1.3 mΩ max at 4.5 V
    • Low RDS(on) results in minimum conduction losses
  • Allows engineers to create robust designs
    • Continuous drain current of 200 A
    • Single pulse avalanche current of 100 A and energy of 500 mJ
  • Low thermal resistance of 0.4 ˚C/W (junction to case)
  • Wide operating temperature range of – 55 ˚C to + 175 ˚C
  • RoHS compliant and halogen free
  • 100 % Rg and UIS tested.
Market Applications:
  • High-power automotive motor drive applications, including electric power steeringProduct Group: Vishay Siliconix, MOSFETs / December 2012
The Key Specifications:
  • Package: 7-pin D2PAK
  • VDS: 40 V
  • VGS: 20 V
  • ID: 200 A
  • RDS(ON):
    • 1.1 mΩ at 10 V
    • 1.3 mΩ at 4.5 V
  • Thermal resistance (junction to case): 0.4 ˚C/W
  • Single pulse avalanche current: 100 A
  • Single pulse avalanche energy: 500 mJ
  • Operating temperature range: – 55 ˚C to + 175 ˚C.
The Perspective:
For automotive applications, the SQM200N04-1m1L combines its 7-pin D2PAK packaging with highdensity n-channel TrenchFET Gen III technology. The result is ultra-low on-resistance down to 1.1 mΩ max at 10 V, which minimizes conduction losses and thus reduces the typical operating temperature of the device.
The SQM200N04-1m1L is manufactured using Vishay’s automotive-specific processes and materials, including a package that allows reliable operation up to 200 A, creating a robust design for automotive applications.
Availability: Samples and production quantities of the new automotive power MOSFET are available now, with lead times of 14 to 16 weeks for large orders.
vishay.com
