u-blox introduces high-performance parallel GPS/GLONASS positioning module
u-blox MAX-M5Q
MAX-M5Q expands u-blox’ popular module series with parallel operation, ideal for ERA-GLONASS.
Swiss u-blox introduces the surface-mount MAX-M5Q, a compact satellite positioning module that supports US GPS, Russian GLONASS as well as Japanese QZSS satellite GNSS systems. High-performance GPS/GLONASS parallel operation is also supported to enhance positioning speed and accuracy.
u-blox - MAX-M5Q
Designed for use in rugged environments and wide temperature range, MAX-M5Q is an ideal positioning solution for industrial machine-to-machine (M2M) applications as well as Russia’s ERA-GLONASS emergency call system. MAX-M5Q enhances positioning in poor GNSS satellite visibility conditions as well as in high latitude and polar regions.
With dimensions of only 9.7 × 10.1 × 2.5 mm, MAX-M5Q is the newest member of u-blox’ ultra-compact MAX GNSS LCC module series. Additional features include autonomous A-GPS that reduces warm start TTFF by as much as 90%, and an embedded data logger which can store location information to internal Flash memory for up to 16 hours at 15 second intervals.
u-blox.com
