Serial UART/SPI To WiFi Modules Bring WiFi To New Products
Radiocom Research RW8200
Embedded serial to WiFi module integrates a M3 Cortex host processor, Broadcom’s BCM44362 WICED and an embedded processor.
Radicom Research’s RW8200 Embedded WiFi Module supports Serial, SPI and optional USB interfaces. It integrates an ARM Cortex-M3 host processor, Broadcom’s Wireless Internet Connectivity for Embedded Devices (WICED) supported Wi-Fi chipset, RF front end, clocks and on-board antennas or U.FL connectors into a compact module. The RW8200 can be used to add state of the art data Wi-Fi wireless operation to any system with minimum engineering resources.
Radiocom выпускает встраиваемые Wi-Fi модули с последовательным интерфейсом RW8200
Featuring self-contained Wi-Fi subsystem, a streamlined and simple connectivity API and complete software development environment, the RW8200 can be used as a standalone Wi-Fi station or network controller. It allows OEM’s to incorporate wireless connectivity into a broad range of products that previously did not feature networking capability.
The RW8200 contains Wi-Fi networking library and software application stack that enables simplified Wi-Fi integration into any MCU based consumer products. It provides Wi-Fi adoption in emerging markets including Connected Home Appliances, Consumer Electronics and Cloud-based Sensors, Healthcare and Security services.
Features:
  • Interfaces: Serial and SPI
  • USB interface available with a Serial-to-USB adapter
  • 802.11 b/g/n compliant
  • Solutions with WLAN, MAC, baseband and
  • power amplifier
  • Wi-Fi client and AP mode support
  • Serial-to-Wi-Fi API interface
  • RTOS & TCP/IP stack support
  • Configurable through AT commands
  • Wi-Fi security: WEP-128, WPA-PSK(TKIP), WPA2-PSK
  • Low power 3.3V operation
  • Extended operating temperature (-30°C to +85°C)
  • Small size: 0.79” × 1.30” × 0.09” (20 × 33 × 2.2mm)
  • On-board antennas or U.FL connectors
  • Dual antennae for MIMO single stream operation
  • Sensor applications support: ADC, DAC, I2C, GPIO
  • Transmit power: +18 dBm @ 11b/11Mbps
  • Maximum receive sensitivity: -96dBm
  • Agency approvals: (pending) FCC, IC & CE
  • RoHS compliant
Samples Applications:
  • Smart Energy:
    • Lighting Control
    • HVAC Control
    • Thermostats
    • Appliances
  • Health Care Devices:
    • Glucose Monitor
    • Heart-rate Monitor
    • Blood Pressure Monitor
    • Fitness Equipment
  • Home / Industrial Automation:
    • Security Cameras
    • Security Alarm System
    • Remote Control
    • Building Automation
radi.com
