e-con Systems Launches Full HD Autofocus 8MP USB 3.0 Camera
e-con Systems See3CAM_80
See3CAM_80 based on Omnivision OV8825 sensor. Capable of uncompressed video streaming 1080p@30fps
e-con Systems Inc. announces the launch of the See3CAM_80, part of the See3CAM family of USB3.0 SuperSpeed cameras.
e-con Systems - See3CAM_80
The See3CAM_80 supports video streaming at resolutions of up to 1080p@30fps and includes an eight megapixel autofocus camera module, the e-CAM80_MI8825_MOD, with an OV8825 CMOS image sensor. The UVC compliant camera is plug-and-play in both Windows and Linux. In Windows, the camera is exposed as a DirectShow device and in Linux, as a V4L2 capture source.
e-con Systems - e-CAM80_MI8825_MOD
The See3CAM_80 supports VGA@30, 720p30, 1080p30 preview resolutions for high end video recording, video analytics and HD video conferencing applications. It can stream the full 8MP resolution video at around 11fps for applications where full image resolution required, but at a lower frame rate. All the above are uncompressed video and streaming is through the USB3.0 interface which supports about 5Gbps bandwidth.
The See3CAM_80 is ideal for customer applications such as document cameras/visualizers, high resolution OCR applications for large sheet sizes, medical and scientific applications such as tissue vision, pathology examination and microscopic applications where high resolution streaming - even at a low frame rate - is required.
The See3CAM_80 makes full use of the potential of its OmniVision’s OV8825 CameraChip sensor. The OV8825 is a 1/3.2” optical format, 1.4 micron pixel raw image sensor with a four-lane MIPI CSI-2 interface and supports 720p60, 1080p60 and also 8MP at 24fps.
Features:
  • Power requirements: 520mA
  • Operating Voltage: 5V ± 250mV
  • View Angle: 55 °
  • Output Format : YUV2
  • Object Distance: 100 mm to Infinity
  • Max S/N ratio: 35.7 dB
  • Board Size in mm (lxb):  65 × 16 mm
  • Lens Size: 8.5 × 8.5 × 5.8 mm
  • Module Size: 24 × 8.5 × 7 mm
  • Dynamic Range: 70.45 dB
See3CAM_80 is available now with starting price $89.
prweb.com
