Infineon is the driver for DC motor control PWM to 20 kHz and maximum current of 7 A
Infineon TLE9201
Infineon released TLE9201SG is a general-purpose 5 A H bridge, designed for (but not limited to) the control of DC motors and other inductive loads in automotive applications. The outputs can be pulse width modulated at frequencies of up to 20 kHz.
Infineon TLE9201SG
PWM/DIR control reduces the number of PWM capable pins needed for the microcontroller interface. The H bridge switches into chopper current limitation mode for load currents above the current limitation threshold (7 A typ.).
The TLE9201 is protected against short circuits and over temperature and provides comprehensive diagnosis via SPI and basic error feedback via status flags. Open load can be detected when the bridge is disabled or during PWM operation of inductive loads.
The robust PG-DSO-12-17 package provides excellent thermal capabilities due to its thick copper heat slug. The protruding edges of the heat slug make this package ideal for automatic optical solder inspection.
Features
  • RDS(on) of 100 mΩ per switch typ. at Tj=25°C
  • Operating battery supply voltage of 5 V to 28 V
  • Logic input of 3.3 V and 5.0 V TTL/CMOS-compatible
  • Low standby current
  • Chopper current limitation
  • Short circuit and overtemperature protection
  • VS undervoltage protection
  • Open load detection in ON and OFF states
  • Detailed SPI diagnosis or simple error flag
  • Green product (RoHS-compliant)
  • AEC-qualified
 Applications
  • Small DC motors with continuous current requirements of maximum 5 A
  • Exhaust gas recirculation systems
  • Variable turbo geometry systems
  • Idle control systems
  • Swirl and tumble flaps
  • Variable intake manifold systems
  • Turbo charger waste gates
  • Any industrial DC motor applicationwith maximum current requirements up to 5 A
infineon-designlink.com
