Epson's New Low-Current Real-Time Clock Module Enables Supercapacitors to Replace Batteries in Electronic Equipment
Epson RX6110SA
Seiko Epson Corporation introduces the industry’s lowest power real-time clock (RTC) module. With typical current consumption of just 130 nA (When operating at 3.0 V), Epson’s RX6110SA current consumption level is 35% lower than that of the RX-8571SA, Epson's existing lowest-current RTC product.
Seiko Epson - RX6110SA
Epson’s RX6110SA enables the reduction of hazardous substances by allowing electronic device makers to replace batteries with supercapacitors. With a 0.33F supercapacitor, Epson’s RX6110SA can operate for 16 weeks. Epson’s RX6110SA achieves an operating current one half of leading competitors by employing special low-power circuit design techniques and Epson’s unique low-leakage IC process technology. Compared to microcontroller implementations, Epson’s RX6110SA can operate eight times longer.
The RX6110SA also includes a diode-less power-supply switching circuit which allows it to operate and charge from power supplies ranging from 5 V down to as low as 1.1V. By operating at a lower voltage than competition, Epson’s RX6110SA further extends battery life.
In addition to keeping time, real-time clocks are used to log power-loss events and save system state when power is lost. Epson’s RX6110SA offers a rich feature set to support these needs, including a 32.768 kHz output, alarms and timers, and RAM. The RX6110SA supports both SPI-bus and I2C-bus interfaces.
Main Specifications
Model number RX6110SA
External dimensions 10.1 × 7.4 × 3.2 (max.) mm
Timekeeper voltage range 1.1 V to 5.5 V
Operating temperature range -40°C to +85°C
Current consumption 130 nA (Typ.) / 250 nA (Max.) (3.0 V during operation)
Initial Frequency Deviation 5.0 ± 23.0 × 10-6(Max.)
Interface SPI-bus and I2C-bus (selectable)
Functions Clock, calendar, alarm, long-term timers,
frequency output, RAM, etc.
epson-electronics.de
