NXP extends its transistor portfolio by releasing 20 new 500 mA resistor equipped transistors (RETs) in SOT23 and SOT323 packages
NXP PDTB1xxxT PDTB1xxxU PDTD1xxxT PDTD1xxxU
NXP extends its transistor portfolio by releasing 20 new 500 mA resistor equipped transistors (RETs) in SOT23 and SOT323 packages. Our product series PDTB1xxxT / PDTB1xxxU and PDTD1xxxT / PDTD1xxxU offer an output current capability of 500 mA, operation voltage of 50 V and built-in bias resistor values from 1 to 10 k Ohm. Designed for high temperature applications of up to 175°C, they are ideal for digital automotive applications.
NXP PDTB1xxxT/U
PDTB1xxxT/U and PDTD1xxxT/U are available as NPN and PNP types in two SMD plastic packages: The 2.9 × 1.3 × 1.0 mm SOT23 and the slightly smaller SOT323 at 2.0 × 1.25 × 0.95 mm. Additionally, the series offer a simplified circuit design, reduced component counts and +- 10% resistor ration tolerance.
NXP PDTB1xxxT/U
Key features and benefits
  • 500 mA output current capability
  • Built-in bias resistors
  • Simplifies circuit design
  • Reduces component count
  • +- 10% resistor ration tolerance
  • AEC-Q101 qualified
  • High temperature applications up to 175 °C
Key applications
  • Digital applications in automotive and industrial segments
  • Controlling IC inputs
  • Switching loads
