NVE Introduces High-Voltage Isolators
NVE
New V-Series Isolators provide best-in-class high-voltage performance of 5000 volts isolation and 1000 working volts
NVE Corporation announced the introduction of versions of its award-winning IsoLoop® Isolators with five kilovolt isolation. The new “V-Series” Isolators provide an unmatched combination of isolation voltage, working voltage, speed, and operating temperature.
NVE High-Voltage Isolators
Best-in-class V-Series specifications include:
  • 5 kVrms isolation (1 minute) per UL 1577
  • 1000 Working Voltage (line voltage) per VDE 0884-10
  • 110 Mbps
  • Up to 125 degrees Celsius operating temperature
  • More than 100 teraohm barrier resistance
A Unique Barrier
Isolation is provided by NVE’s unique ceramic/polymer composite isolation barrier with a barrier resistance of 100 teraohms and an extrapolated life of 44000 years.
True 8 millimeter Creepage
The new isolators use NVE’s True 8™ isolator package, which meets demanding eight millimeter creepage requirements under IEC 60601. With ordinary wide-body packages, full eight millimeter creepage cannot be assured.
Rigorous Testing
V-Series Isolators are 100% tested to 6000 Vrms (8486 Vpeak), and to a best-in-class 1000 Vrms Working Voltage per VDE 0884-10.
Popular Applications
The new parts are ideal for demanding applications such as medical instruments, smart-grid interfaces, motor drives, and power supplies.
Available Now
V-Series versions of our most popular part types are available now, and more will be added.
nve.com
