TI introduces ultra-low quiescent current, high-voltage LDOs for direct-to-battery automotive applications
Texas Instruments TPS7A16xx-Q1 TPS7A66xx-Q1 TPS7B67xx TPS7B4250-Q1
Broadening its large portfolio of low drop-out regulators (LDOs), Texas Instruments (TI) introduced 17 new AEC-Q100-qualified, high-voltage LDOs for automotive and industrial applications. The new ultra-low quiescent current LDOs, including the TPS7A16xx-Q1 with 60-V input, TPS7A66xx-Q1 and TPS7B67xx families, and the TPS7B4250-Q1 LDO, support many applications that connect directly to a car or truck battery, such as cluster, power steering and infotainment systems, door modules and lighting controls.
Texas Instruments - TPS7A16xx-Q1, TPS7A66xx-Q1, TPS7B67xx, TPS7B4250-Q1
Key features and benefits of the new LDOs:
  • Ultra-low quiescent current extends battery life:
    The new LDOs achieve quiescent current as low as 10 uA in standby mode, resulting in lower power consumption and increased battery life.
  • Internal equivalent series resistance (ESR) compensation can help optimize system cost and stability:
    Designers have the flexibility to choose from a wide range of output capacitors, including ceramic, to reduce system cost and increase stability.
  • High input voltage allows automotive subsystems to connect directly to the car battery:
    The LDOs support input voltages of up to 40 V for normal operation and up to 45 V to support transient spikes in automotive designs. Additionally the TPS7A1601-Q1 can support up to 60-V normal operation for trucks and heavy-duty equipment.
  • Tracking function allows for more accurate data from the off-board sensors:
    Tracking provides close to zero tolerance between on-board and off-board power supplies. Tracking helps customers get more accurate data from the off-board sensors.
  • Integrated window watchdog supports functional safety:
    The integrated window watchdog enables customers to meet the functional safety requirements on the system level.
Tools and support
Designers can test drive the new AEC-Q100-qualified LDOs using several featured evaluation modules and SPICE simulation models that make it easy to evaluate and design.
Availability, packaging and pricing
The TPS7A16xx-Q1 LDOs are available in an 8-pin MSOP-PowerPad package priced at US$1.65 in 1,000-unit quantities. The TPS7A66xx-Q1 LDOs are available in an 8-pin MSOP-PowerPad package priced at US$0.60 in 1,000-unit quantities. The TPS7B67xx-Q1 LDOs are available in a 20-pin HTSSOP package priced at US$0.80 in 1,000-unit quantities.
ti.com
