Intersil Announces Industry's First Rad Tolerant 36V Instrumentation Amplifier with Integrated Differential ADC Driver
Intersil ISL70517SEH ISL70617SEH
ISL70617SEH provides highest sensor signal processing performance for communication satellite applications
Intersil Corporation introduced the industry's first radiation tolerant 36 V instrumentation amplifier (in-amp) featuring an integrated differential analog-to-digital converter (ADC) driver. The high performance ISL70617SEH differential input, rail-to-rail output in-amp delivers the industry's highest signal processing performance for low-level sensor telemetry data critical to communication satellites. Its high integration and best-in-class performance reduces system size, weight and power (SWAP) costs, and accelerates time to market.
Intersil - ISL70617SEH
The ISL70617SEH enables higher common-mode rejection ratio (CMRR) and power supply rejection ratio (PSRR) than the competition, at all gain settings. Designers can easily program the in-amp's gain from 0.1 to 10,000 using two external resistors. The device is wafer-by-wafer guaranteed to 75 krad (Si) with a low dose rate exposure of 10 mrad/sec, which more closely resembles the space environment than the high dose rate testing used with competitive devices. The ISL70617SEH leverages Intersil's proprietary silicon on insulator process to provide single event latch-up (SEL) and single event burnout (SEB) robustness of 60 MeV in heavy ion environments. And its single event transient (SET) performance of <10 µsec eliminates the need for extra filtering.
The ISL70517SEH joins the ISL70617SEH, and offers similar features but implements a differential input and rail-to-rail single-ended output. Both in-amps allow designers to power the input/output stages from different supplies using individual power supply pins. Designers are able to take the input signals riding on a high common-mode voltage and level shift them to a low voltage device. For example, Intersil's in-amps can protect downstream ICs from high voltage signals by tying the amplifier's rail-to-rail output to an ADC's low voltage power supply. This also preserves the ADC maximum input dynamic range and eliminates ADC input overdrive.
Key Features and Specifications of ISL70617SEH and ISL70517SEH
  • Low input offset of 30 µV, and low input bias current of 0.2 nA
  • Excellent CMRR and PSRR of 120 dB typical for attenuating, gaining and filtering sensor signals to improve signal quality
  • Wide operating range from ±4 V to ±18 V covers the majority of analog supply rails
  • Closed loop –3 dB BW 0.3 MHz (AV = 1k) to 5.5 MHz (A = 0.1)
  • Extended operating temperature range of –55 °C to +125 °C
  • Electrically screened to DLA SMD# 5962-15246
  • Acceptance tested to a higher dose level of 75 krad (Si), wafer-by-wafer
  • Industry's lowest dose rate (0.01 rad(Si)/s) radiation tolerance of 75 krad (Si)
  • SEB LETTH (VS = ±18 V) immune up to 60 MeV×cm2/mg
Availability
The ISL70617SEH differential I/O instrumentation amplifier and ISL70517SEH single-ended instrumentation amplifier are available now in 24-lead ceramic flatpack packages. Evaluation boards are available to evaluate device features and performance, and SEE and total dose testing reports are available for both devices.
ISL70617SEHEV1Z Evaluation Board
ISL70617SEHEV1Z Evaluation Board.
