Linear Technology Introduced 16-bit Analog-to-Digital Converter
Linear Technology LTC2208
The LTC2208 from Linear Technology is a 130Msps, sampling 16-bit A/D converter designed for digitizing high frequency, wide dynamic range signals up to input frequencies of 700MHz. The input range of the ADC can be optimized with the PGA front end.
LTC2208
The LTC2208 is perfect for demanding communications applications, with AC performance that includes 78 dBFS Noise Floor and 100 dB spurious free dynamic range (SFDR). Ultra low jitter of 70 fsRMS allows undersampling of high input frequencies with excellent noise performance. Maximum DC specs include ±4 LSB INL, ±1 LSB DNL (no missing codes) over temperature.
The digital output can be either differential LVDS or single-ended CMOS. There are two format options for the CMOS outputs: a single bus running at the full data rate or demultiplexed buses running at half data rate. A separate output power supply allows the CMOS output swing to range from 0.5 V to 3.3 V.
The ENC+ and ENC inputs may be driven differentially or single-ended with a sine wave, PECL, LVDS, TTL or CMOS inputs. An optional clock duty cycle stabilizer allows high performance at full speed with a wide range of clock duty cycle.
