Teledyne Relays Introduced New Phase Control SSR
Teledyne Relays SHP
The Series SHP from Teledyne Relays phase angle controller has an analog input isolated from the mains to vary the phase angle proportionally to the input and load voltage. The SHP phase angle controller is designed mainly for resistive loads. The SHP may be used with inductive loads, but with limitations. It provides internal protection from load transients. Two versions are available: DC control and AC control.
SHP
  • Phase angle controller - microcontroller inside
  • Analog switching
  • Overvoltage proctection by varistor
  • Green LED for input visualization
  • IP20 touch-proof flaps
  • Short-circuit protection
  • Designed in conformity with EN60947-4-3 (IEC947-4-3) and EN60950/VDE0805 (Reinforced Insulation)
