National Semiconductor Introduces 1.0 Gbps LVDS Buffer/Repeater
National Semiconductor DS10BR150
The DS10BR150 is a single channel 1.0 Gbps LVDS buffer optimized for high-speed signal transmission over lossy FR-4 printed circuit board backplanes and balanced cables. Fully differential signal paths ensure exceptional signal integrity and noise immunity.
Wide input common mode range allows the receiver to accept signals with LVDS, CML and LVPECL levels; the output levels are LVDS. A very small package footprint requires a minimal space on the board while the flow-through pinout allows easy board layout. The differential inputs and outputs are internally terminated with a 100 Ω resistor to lower device input and output return losses, reduce component count and further minimize board space.
Features
  • DC - 1.0 Gbps low jitter, high noise immunity, low power operation
  • On-chip 100§Щ input and output termination minimizes insertion and return losses, reduces component count and minimizes board space
  • 7 kV ESD on LVDS I/O pins protects adjoining components
  • Small 3 mm x 3 mm 8-LLP space saving package
Applications
  • Clock and data buffering
  • OC-12 / STM-4
  • Fibre Channel (1GFC)
  • FireWire 800
Category: Interface
