Advanced Search +
11-21-2017
Toshiba Expands Line-up of Latest Generation Trench MOSFETs with Ultra-Compact 40V Device for Low EMI Designs
Toshiba » TPH1R204PB
N-channel U-MOS-IX-H MOSFET with integrated SRD is ideal for power supplies and motor drives
Toshiba Electronics Europe has expanded its line-up of MOSFETs based on its latest generation U-MOS-IX-H trench semiconductor process with a new, ultra-compact 40 V device featuring an integrated soft recovery diode (SRD).
Toshiba - TPH1R204PB
Thanks to the integrated SRD, the TPH1R204PB is able to keep the spike voltages generated between the drain and source during switching very low. This makes the MOSFET suitable for synchronous rectification in the secondary side of switching power supplies that require low EMI. Target applications include high-efficiency AC-DC and DC-DC converters as well as motor drives, for example in cordless tools.
The TPH1R204PB is an N-channel device with a maximum on resistance (RDS(ON)) of only 1.2 mΩ (@ VGS = 10 V). Rated output charge (QOSS) is just 56 nC. The device is supplied in a SOP advance package measuring just 5 mm × 6 mm × 0.95 mm.
Slices ↓
