Microprocessor Supervisory Circuit from Diodes Incorporated Monitors System Voltage with Programmable Delay
Diodes PT7M3808
Diodes Incorporated announced the PT7M3808 family of microprocessor supervisory circuits. These devices monitor system voltages from 0.4 V to 5.0 V, and feature threshold accuracy from 0.5% and an adjustable delay time from 1.25 ms to 10 ms; this allows these small form-factor devices to enable power-on reset functionality for microprocessor and other digital systems while also consuming minimal power. Applications include notebook and desktop computers, and battery-powered portable equipment for markets ranging from data centers to security systems.
Diodes - PT7M3808
Offered in fixed-threshold versions for standard voltage rails between 0.9 V and 5.0 V, and with an adjustable threshold version down to 0.4 V, the PT7M3808 uses a precision reference to provide a 0.5% negative-going input threshold accuracy when monitoring voltages up to 3.3 V and 1% accuracy at voltages from 3.3 V to 5.0 V. The delay time is adjusted from 1.25 ms to 10 ms by connecting an external capacitor to the pin; a longer 20 ms delay can be achieved by disconnecting the CT pin, while a 300 ms delay is possible by connecting the CT pin to VDD with a resistor.
Adjustable Voltage Diagram   Fixed Voltage Diagram
Adjustable Voltage Diagram.   Fixed Voltage Diagram.
The PT7M3808 has a very low quiescent current, typically 2.8 μA, making it well-suited for battery-powered applications. Available in SOT26 and DFN2020-6 packages, the PT7M3808 takes up very little board space for both new and drop-in replacement designs.
