Offline Buck Converter for the IoT Applications from Diodes Incorporated
Diodes AL17050
Diodes Incorporated announced the AL17050 universal offline buck converter designed for lowpower Internet-of-Things (IoT) applications. With its wide AC input voltage range and fully integrated MOSFET, it provides a compact and efficient solution to generating a constant voltage for low-power applications that need to comply with strict standby power restrictions.
Diodes - AL17050
The AL17050 has been developed to accept an AC input voltage between 85 VAC and 265 VAC, making it suitable for any region. The internal MOSFET is able to withstand voltages of up to 500 V yet is optimized for low-power applications, meaning the device only consumes 100 μA of static current. Furthermore, the device automatically adjusts to low loads, so it delivers excellent overall efficiency.
Typical Applications Circuit
Typical Applications Circuit.
The non-isolated design minimizes the BoM for manufacturers developing applications for the IoT, such as smart appliances, smart sensors, and connected lighting. The AL17050 delivers a constant 3.3 V/5 V at up to 60 mA, making it ideal for devices based on low power microcontrollers (MCUs) that integrated IoT connectivity such as Bluetooth® LE or Zigbee™.
Using the AL17050, manufacturers will be able to develop IoT applications that are powered directly from a high-voltage AC supply yet deliver outstanding power efficiency. With the number of devices in the IoT expected to rise to many billions in the next few years, energy efficiency is now a major design consideration. Alongside its excellent regulation and high-power efficiency, the AL17050 also integrates protection against over-temperature, over-load, output-short, and openloop conditions. It is available in the SOT25 package and requires very few additional components in a buck converter configuration, making it suitable for small products where space is often limited.
