Analog Devices' Precision ±10V and 0-20mA A/D Converters Simplify PLC Module Development
Analog Devices AD4111 AD4112
Analog Devices (ADI) introduced two multi-channel ±10 V and 0-20 mA precision A/D converters that better enable implementation of programmable logic controller (PLC) and distributed control system (DCS) modules. Leveraging ADI’s iPassives® integrated precision passives technology, the AD4111 and AD4112 A/D converters integrate precision matched current sense resistors and resistor dividers. The high degree of channel-to-channel matching simplifies calibration requirements, and with support for up to eight single-ended voltage inputs and four current inputs, makes the new products ideal for use as reconfigurable platform solutions, while reducing size, complexity and cost in PLC and DCS modules.
Analog Devices - AD4111, AD4112
The AD4111 and the AD4112 A/D converters can accept ±10 V while meeting performance specifications and has a functional range of ±20 V, adding over-range margin to the nominal ±10 V. They can also accept currents of –0.5 to 24 mA while meeting performance specifications. This allows reliable measurements close to 0 mA and provides over range margin past 20 mA. The devices offer an Absolute Maximum Rating of ±50 V on voltage pins and ±50 mA on current pins. The AD4111 uniquely enables open wire detection, to detect when an external sensor or signal source is disconnected from the system input, on ±10 V voltage inputs while operated from either a +5 V or +3.3 V single power supply.
When used in conjunction with the ADuM5411 quad-channel digital isolator, the AD4111 supports EMC standards IEC 61000-4-2, IEC 61000-4-3, IEC 61000-4-4, IEC 61000-4-5, IEC 61000-4-6 and CISPR 11.
AD4111 Product Highlights:
  • Single 3.3 V or 5 V supply
  • Single design supports both voltage and current inputs
  • Integration of precision matched current sense resistor and resistor dividers
  • ±10 V specified input voltage range and ±20 V functional input voltage range
  • >1 MΩ input impedance
  • Enables open-wire detection
Pricing and Availability
Product Full Production Price Each per 1,000 Packaging
AD4111 Now $7.25 40ld LFCSP (6×6×0.95 mm)
AD4112 Now $6.45 40ld LFCSP (6×6×0.95 mm)
EVAL-AD4111SDZ Evaluation Board Now $59.00 Each
EVAL-AD4112SDZ Evaluation Board Now $59.00 Each
The EVAL-AD4111SDZ Evaluation Board
The EVAL-AD4111SDZ Evaluation Board.
