Epson Shipping Samples of New Interface Conversion IC for In-Vehicle Systems
Epson S2D13V70
S2D13V70 contributes to efficient development of automotive display systems
Seiko Epson Corporation has developed a new interface conversion IC for in-vehicle systems that converts eDP (Embedded DisplayPort) video signals to OpenLDI (open LVDS display interface). Samples of the S2D13V70 interface converter are now available. Epson plans to produce 100,000 of these chips per month.
Epson - S2D13V70
Both eDP and OpenLDI are interface standards for transmitting video signals to displays, but eDP supports higher resolution video and faster speeds than the more widely used OpenLDI.
With the electrification and automation of automobiles, manufacturers will increasingly require higher resolution displays in in-vehicle systems such as instrument clusters and central information displays. As this trend accelerates, products that support eDP, which can transfer video signals at higher rates, are growing in popularity in ECUs that control in-vehicle displays. On the other hand, in-vehicle displays that support eDP input are not yet mainstream, and since displays are connected using an OpenLDI interface, eDP output signals from an ECU have to be converted to OpenLDI in the development of in-vehicle systems.
To address this issue in in-vehicle systems development, Epson developed the S2D13V70, an interface conversion IC that supports automotive standards. The new product satisfies the strict quality requirements of the automotive industry. It is compliant with AEC-Q100 and operates at temperatures up to 105 °C.
The conversion IC is also equipped with safety functions required for automotive systems. For example, a CRC function monitors whether video signals output from an ECU are being properly received, and a blank screen function masks the display with a particular image pattern when a problem is detected in the transmission path between an ECU and the conversion IC.
The IC supports the design of dual-display instrument clusters, with a splitter function that splits and outputs video signals on two displays.
Product features
  • Automotive standards-compliant eDP to OpenLDI interface conversion IC
  • Extensive safety functions (SPI connection, CRC, blank screen)
  • Splitter function that enables video of the same resolution up to full-HD to be simultaneously output on two displays
