Nexperia introduces industry's fastest Common Mode Filters with Integrated ESD Protection for Super Speed USB
Nexperia PCMF1USB3BA PCMF2USB3BA PCMF3USB3BA
Widest differential passband; high surge robustness and low clamping
Nexperia announced the market’s fastest common mode filter (choke)/ ESD protection combination. The new PCMFxUSB3BA/C features the industry’s widest differential passband of up to 10 GHz 3 dB frequency and a very high surge robustness of up to 7.5 A 8/ 20 µs. It is designed to suppress common mode and single-ended noise while minimizing the impact on the signal integrity of extremely fast data lines.
Nexperia - PCMF1USB3BA, PCMF2USB3BA, PCMF3USB3BA
Developed to meet the requirements of Super Speed USB applications, the new devices provide effective 1, 2 & 3 line pair protection (Tx +/-, Rx +/-, D +/-) and filtering. Proven for 10 Gbps communications line protection, the filter’s system-level robustness exceeds the IEC 61000-4-2 level 4, suiting them for use with sensitive SoCs. The solution also minimizes reflections when compared to a discrete design. The integration of Nexperia’s TrEOS technology results in low clamping and high robustness. PCMFxUSB3BA/C extends Nexperia’s family of Common Mode Filters (PCMF devices), helping to optimize the choice between differential pass-band and common-mode rejection at signal fundamentals and higher harmonics.
Schematic Diagram of the PCMF1USB3BA/C in the WLCSP5 Package
Schematic Diagram of the PCMF1USB3BA/C in the WLCSP5 Package.
Comments Stefan Seider, Product Manager, Nexperia: “Apart from their capability to reduce EMI, Common Mode Filters with ESD protection are also very popular for their efficiency in protecting sensitive transceivers: They add an impedance to the signal line pair, which is very small for differential signals but shows significant attenuation of common mode noise as well as single-ended transients such as ESD.”
The new PCMF filters are available in very low-inductance, space-saving WLCSP packages. Devices are footprint-compatible with available ESD-only solutions for fast design changes.
