Texas Instruments introduced Small-Size nanopower comparators TLV7031-Q1 and TLV7041-Q1
Texas Instruments TLV7031-Q1 TLV7041-Q1
Texas Instruments introduced the new low-voltage, nanopower, single-channel comparators TLV7031-Q1/ TLV7041-Q1.These comparators are available in a standard 5-pin SC70 package, making them applicable for space-critical and power conscious designs like infotainment, telematics, and head unit applications.
Texas Instruments - TLV7031-Q1, TLV7041-Q1
The TLV7031-Q1 and TLV7041-Q1 offer an excellent combination of power and speed, with a quiescent supply current of 390 nA and a propagation delay of 3 μs. The benefit of fast response time at nanopower enables power-conscious systems to monitor and respond quickly to fault conditions. With an operating voltage range of 1.6 V to 6.5 V, these comparators are compatible with 1.8 V, 3 V, and 5 V systems.
The TLV7031-Q1 and TLV7041-Q1 also ensure no output phase inversion with overdriven inputs and internal hysteresis, so engineers can use this family of comparators for precision voltage monitoring in harsh, noisy environments where slow-moving input signals must be converted into clean digital outputs.
The TLV7031-Q1 has a push-pull output stage capable of sinking and sourcing milliamps of current when controlling an LED or driving a capacitive load. The TLV7041-Q1 has an open-drain output stage that can be pulled beyond VCC, making it appropriate for level translators and bipolar to single-ended converters.
Features
  • Qualified for automotive applications
  • Tiny 5-pin SC70 package
  • Wide supply voltage range of 1.6 V to 6.5 V
  • Quiescent supply current of 390 nA
  • Low propagation delay of 3 μs
  • Internal hysteresis of 6.5 mV
  • Rail-to-rail common-mode input voltage
  • Internal Power-On-Reset provides a known startup condition
  • No phase reversal for overdriven inputs
  • Push-pull output (TLV7031-Q1)
  • Open-drain output (TLV7041-Q1)
  • –40 °C to 125 °C Operating temperature
Applications
  • Telematics eCall
  • Automotive head unit
  • Instrument cluster
  • Audio amplifier
  • On-board (OBC) & wireless chargers
Package, availability and pricing
The TLV7031-Q1 and TLV7041-Q1 are now available from TI and authorized distributors in a SC70 package. Pricing starts at US$0.16 in 1,000-unit quantities.
