Analog Devices Announces High Speed I2C to CAN-Physical Transceiver
Analog Devices LT3960
Analog Devices has introduced the robust high speed transceiver LT®3960 that extends a single-master I2C bus through harsh or noisy environments at up to 400 kbps using the CAN-physical layer. One LT3960 sits near the I2C master, creating from SCL and SDA equivalent differential buses (I2CAN) on two twisted pairs. At the other end of the twisted pairs, a second LT3960 recreates the I2C bus locally for any slave I2C devices. A built-in 3.3 V LDO powers both the I2C and I2CAN buses from a single input supply from 4 V to 60 V. Alternatively, the LT3960 can be powered directly from a 3.3 V or 5 V supply.
Analog Devices - LT3960
The LT3960 is available in a 10-lead MSOP package.
I2CAN Bus Link with Large Ground Loop Voltage
I2CAN Bus Link with Large Ground Loop Voltage.
Features
  • Protected from Overvoltage Line Faults to ±40 V
  • Up to 400 kbps I2C Communications
  • 4 V to 60 V Power Supply Range with Internal 3.3 V Regulator
  • 3.3 V or 5 V Bus Voltage
  • Extended Common Mode Range (±36 V)
  • ±8 kV HBM ESD on CAN Pins, ±2 kV HBM ESD on All Other Pins
  • Current Limited Drivers with Thermal Shutdown
  • Power-Up/Down Glitch Free Driver Outputs
  • Low Current Shutdown Mode
  • Transmit Data Dominant Timeout Function
  • E- and J-Grades Available
  • Available in a 10-Lead MSOP Package
  • AEC-Q100 Qualification in Progress
Receiving I2C Traffic Across ±25 V Common-Mode Differential
Receiving I2C Traffic Across ±25 V Common-Mode Differential.
Applications
  • Industrial Networking
  • Automotive Networking
  • Remote Sensors
Demonstration circuit DC2686A for LT3960
Demonstration circuit DC2686A for LT3960.
