Texas Instruments announces High-Speed RRI Comparator with LVDS Outputs
Texas Instruments TLV3604 TLV3605
Texas Instruments has announced TLV3604 and TLV3605 800-ps, high-speed comparators with LVDS outputs and rail-to-rail inputs. These features, along with an operating voltage range of 2.4 V to 5.5 V and a high toggle frequency of 3 Gbps, make the TLV3604 and TLV3605 well suited for LIDAR, clock and data recovery applications, and test and measurement systems.
Texas Instruments - TLV3604, TLV3605
Likewise, the TLV3604 and TLV3605 have strong input overdrive performance of 350 ps and are able to detect narrow pulse widths of just 600 ps. This combination of low variation in propagation delay due to input overdrive and the ability to detect narrow pulses improve system performance and extend distance range in Time-of-Flight (ToF) applications. The Low-Voltage-Differential-Signaling (LVDS) output of the TLV3604 and TLV3605 also helps increase data throughput and optimizes power consumption. The complementary outputs reduce EMI by suppressing common mode noise on each output. The LVDS output is designed to drive and interface directly with downstream devices that accept a standard LVDS input, such as high-speed FPGAs and CPUs.
The TLV3604 is in a tiny 6 pin SC-70 package, which makes it easier for space sensitive applications such as an optical sensor module. The TLV3605 maintains the same performance as the TLV3604, and offers adjustable hysteresis control, shutdown, and latching features in a 12 pin QFN package making it an excellent choice for test and measurement applications.
Features
  • Low propagation delay: 800 ps
  • Low overdrive dispersion: 350 ps
  • Quiescent Current: 12.1 mA
  • High toggle frequency: 1.5 GHz/ 3.0 Gbps
  • Narrow pulse width detection capability: 600 ps
  • LVDS output
  • Supply range: 2.4 V to 5.5 V
  • Input common-mode range extends 200 mV beyond both rails
  • Low input offset voltage: ±5 mV
  • Packages: 6-Pin SC70, 12-Pin QFN (3 mm × 3 mm)
The TLV3604EVM Evaluation Module for TLV3604 comparator
The TLV3604EVM Evaluation Module for TLV3604 comparator.
