Analog Devices Announces Industry's Fastest 16-Bit ADC at 250 MSPS
Analog Devices AD9467
ADI continues to set converter performance standard with new AD9467; enables advances in radar systems, spectrum analyzers and multi-carrier, multi-mode receiver designs for wireless infrastructure.
Norwood, MA (09/27/2010) - The industry’s fastest 16-bit ADC (analog-to-digital converter)--at 250 MSPS (mega samples per second)--was unveiled today by data converter market share leader Analog Devices, Inc. (ADI). The AD9467 16-bit, 250 MSPS ADC operates on 35% less power at 25% higher sampling rate than any other 16-bit data converter, providing a new level of signal processing performance for test and measurement instrumentation, defense electronics, and communications applications where high resolution over a wide bandwidth is needed. The AD9467 delivers resolution and a fast sample rate while simultaneously achieving a high SFDR (spurious-free dynamic range) of up to 100 dBFs and SNR (signal-to-noise ratio) performance of 76.4 dBFS. The device’s SFDR of 90 dBFS up to 300 MHz analog input and 60-femtosecond rms (root mean square) jitter helps lower the signal chain bill of materials component count by allowing engineers to increase system performance at higher intermediate frequencies, thereby reducing the number of signal down-conversion stages.
Analog Devices - AD9467
“We needed a 16-bit, 250 MSPS data converter with 90 db of SFDR for one of our key customer's highly advanced, data acquisition systems,” said Brian Kimball, principal hardware engineer, Mercury Computer Systems, a leading provider of open, application-ready, multi-INT subsystems for the intelligence, surveillance and reconnaissance market “The AD9467 data converter was designed into this system because it met our customer’s SFDR, ENOB (effective number of bits), and power requirements. Analog Devices engineers worked with us as trusted advisors to provide early-access silicon and provided design support to enable the timely development of our prototype product.”
The AD9467 can be used with ADI’s AD9523/24 low-jitter clock generators and ADL5562 3.3 GHz ultra-low distortion RF/IF differential amplifier to provide a data conversion signal chain solution.
“The AD9467 converter is attractive to National Instruments because of its industry-leading combination of sample rate and resolution,” said Phil Hester, senior vice president of R&D, National Instruments, a leading global supplier of hardware and software for engineers. “We are currently developing a module based on the AD9467 for our NI FlexRIO product family, which couples this new data conversion performance point with FPGAs that can be programmed using NI LabVIEW software. The AD9467 helps us maintain leadership in providing innovative solutions for test and measurement, software-defined radio, medical imaging, and scientific research applications.”
AD9467 16-bit, 250 MSPS ADC Key Features and Benefits:
  • 16-bit resolution with high signal bandwidths up to 300 MHz enables advanced signal acquisition subsystems in common radio platforms, radar systems, and spectrum analysis.
  • On-chip IF (intermediate frequency) sampling circuit and buffered analog inputs optimize the AD9467 for the highest ENOB and ease of use.
  • High dynamic range over broad signal bandwidth enables software-defined radios for use with multiple standards, such as LTE/W-CDMA, MC-GSM (class 1) and CDMA.
  • Programmable full-scale input range allows trade-off between SNR and SFDR enabling the design of more sensitive radar systems with the ability to acquire and track smaller targets with better accuracy. See chart below.
Input Span
SNR
SFDR
Analog Input
Sample Rate
2.5 Vp-p
74.4 dBFs
90 dBFs
300 MHz
250 MSPS
2.0 Vp-p
74 dBFs
95 dBFs
170 MHz
250 MSPS
2.5 Vp-p
76 dBFs
100 dBFs
100 MHz
160 MSPS
Pricing, Availability, and Tools
Product
Production
Release
Resolution
(Bits)
Sample Rate
(MSPS)
Price Each In
1,000
Packaging
AD9467-250
November 2010
16
250
$120
72-lead FCSP
AD9467-200
November 2010
16
200
$100
72-lead FCSP
AD9467-00EBZ
November 2010
$300 per unit in
single unit uantities
AD9467-50EBZ
November 2010
$300 per unit in
analog.com
