FTDI unveils VINCULO, a powerful development platform for embedded systems requiring USB 2.0 connectivity
FTDI Vinculo
Low-cost development platform featuring USB Host/Slave controller with integrated 16-bit CPU unleashes new possibilities for cost effective embedded design USB silicon and software specialist Future Devices Technology International Limited (FTDI) announces Vinculo, an embedded development platform inspired by the popular Arduino Duemilanove / Uno.
FTDI:  Vinculo development platform
The Vinculo platform allows designers to integrate powerful USB 2.0 interfacing by incorporating FTDI’s Vinculum II VNC2-64 dual-channel Host/Slave controller with the capability of interfacing to the growing range of I/O application boards (shields) developed by the Arduino open-source community. The VNC2 combines a 16-bit/48 MHz CPU core, 256KBytes of Flash memory and 16KBytes of SRAM memory and provides support for external UART, FIFO, PWM, GPIO and SPI Slave/Master interfaces.
The Vinculo platform brings together all of the hardware and software needed for rapid development of innovative, cost-effective embedded systems.
As a further enhancement, the Vinculo module integrates an 8-channel, 10-bit analogue-to-digital converter (ADC). Vinculo also supports 38 general-purpose input/output (GPIO) connections, and USB A and mini B (host and device) connectors on a board measuring just 55.38 mm x 68.58 mm.
The onboard ADC simplifies connection to sensors, actuators and other analogue devices and, in conjunction with the PWM interface on the VNC2, allows Vinculo to effectively control many analog systems. Existing I/O boards (shields) can connect to the Vinculum II VNC2 via the GPIO connections.
The Vinculo programming language utilises a subset of standard ANSII ‘C’ with FTDI supported, free of charge software development tools, libraries and reference designs. The ‘Proto’ board allows designers to create their own shields. LEDs, connectors, and other components are provided ready for assembly onto the prototyping board (which has the same board profile as the Vinculo).
Firmware can be developed using the Vinculum II development tool chain which provides an integrated development environment (IDE) including C compiler, assembler, linker and debugger tools. FTDI provides robust device class driver libraries, including USB Mass Storage, HID (Human Interface Devices), Printer Class, Image Class, Communication Class and Instrumentation.
The FTDI Vinculo base module (VNCLO-MB1A) is available at a cost of $29.95 and the Proto board kit (VNCLO-SHLD-1A) for $9.75 for single units.
ftdichip.com
