Renesas R8C/34K microcontrollers lineup
Renesas R5F21348KDFP R5F21348KNFP R5F2134CKDFP R5F2134CKNFP
Product Overview:
The R8C/34K is based on the R8C CPU Core. Maximum operating frequency is 20MHz. A Flash Memory Version is available. Internal Flash Memory is programmable on a single power source.
Key Features:
  • 8-bit Multifunction Timer with 8-bit prescaler (Timer RA and RB): 2
  • 16-bit Input Capture/Output Compare Timer (Timer RC and RF): 2
  • UART/Clock Synchronous Serial Interface: 4 channels
  • I2C-bus Interface (IIC)/Synchronous Serial Communication Unit: 1 channel
  • LIN Module: 1 channel (Timer RA, UART0)
  • USB Module (Host/Peripheral): Full-speed (12 Mbps, USB 2.0 specification compliant)
  • 10-bit A/D Converter: 12 channels
  • Comparator: 2
  • DTC (Data Transfer Controller): 1 channel
  • Watchdog Timer
  • Clock Generating Circuits: XIN Clock Generation Circuit, On-chip Oscillator (High/Low Speed), PLL Frequency Synthesizer
  • Oscillation Stop Detection Function
  • Voltage Detection Circuit
  • Power-On Reset Circuit
  • I/O Ports: 36 (incl. LED drive ports)
  • External Interrupt Pins: 9
  • Data Flash with Background Operation (BGO) function: 4KB
Key Applications:
Peripherals (USB applicable), audio components, cameras, televisions, household appliances, office equipment, communication devices, mobile devices, industrial equipment, and other applications.
R8C/34K Block diagram
Renesas R8C/34K Block diagram
Click to enlarge
Product Lineup:
R8C/34K
Part No. ROM RAM ROM Type Operating Frequency / Supply Voltage
 R5F21348KDFP 64K + 4K 8K Flash memory 20MHz/3.0V to 5.5V(when using USB),
20MHz/2.7 to 5.5V,
5MHz/1.8 to 5.5V
 R5F21348KNFP 64K + 4K 8K Flash memory 20MHz/3.0V to 5.5V(when using USB),
20MHz/2.7 to 5.5V,
5MHz/1.8 to 5.5V
 R5F2134CKDFP 128K + 4K 10K Flash memory 20MHz/3.0V to 5.5V(when using USB),
20MHz/2.7 to 5.5V,
5MHz/1.8 to 5.5V
 R5F2134CKNFP 128K + 4K 10K Flash memory 20MHz/3.0V to 5.5V(when using USB),
20MHz/2.7 to 5.5V,
5MHz/1.8 to 5.5V
renesas.eu
