Packaged in a space-saving 16-pin TQFN and 14-pin TSSOP, the MAX3456E is a pin-for-pin compatible upgrade to the MIC2550A. Available in the same TQFN and TSSOP packages, the MAX3453E-MAX3455E provide additional features utilizing the unused pins of the MAX3456E. The MAX3453E/MAX3454E include a 1.5k
pullup resistor and enumerate input, enabling software control of USB enumeration and eliminating the need for an external resistor. The MAX3453E/MAX3455E detect the availability of VBUS and provide a logic-level output to the ASIC/CPU. The MAX3454E-MAX3456E are compliant to the USB specification revisions 1.1 and 2.0, and operate at both low speed (1.5Mbps) and full speed (12Mbps). The MAX3453E is specified only for full-speed operation.
The MAX3454E/MAX3456E are powered in three ways: VBUS from the USB host, directly from a Li+ ion battery, or from a 3.3V supply. The MAX3453E/MAX3455E require a 4V to 5.5V supply provided by the USB host. All devices feature a low-power suspend mode and work with ASICs that operate down to 1.65V.
The MAX3453E-MAX3456E are specified over the extended temperature range (-40°C to +85°C). Prices start at $0.73 (1000-up, FOB USA).
| Additional Information: |
QuickView Data Sheet
Full Data Sheet (PDF) Product Advertisement (PDF) |
