New LD6806 family of LDOs feature very low noise performance, low standby current and outstanding ESD protection
NXP Semiconductors announced the availability of the LD6806CX4 ultra low-dropout voltage regulator (LDO), featuring ultra-low dropout of only 60 mV at a 200-mA current rating. With an ultra-small 0.76 x 0.76 x 0.47mm wafer-level chip-scale package (WLCSP), the LD6806CX4 uses minimal board space, making it ideal for extremely space-constrained designs in mobile handsets, where battery life is also a critical success factor. Batteries in mobile phones discharge almost linearly over time, but the LDO compensates for this effect by providing a constant regulated output voltage. For example, if the battery voltage of a smartphone goes down to 3.0 V, due to the low dropout voltage the LD6806CX4 is still able to support an SD card application with a mandatory and stable supply voltage of 2.9 V. The LD6806CX4 is part of NXP’s new LD6806 family of LDOs, which are available immediately from major distributors.
WLCSP | SOT886 | SOT753 | SOT1194 |
Key Features of LD6806 Series
- NXP’s new LD6806 LDO series features a very low noise performance of only 30 μVRMS, which helps prevent changes in the regulated output voltage and eliminates the need for an external dedicated noise-reducing capacitor.
- Battery-powered applications are also supported by the low standby current of 0.1 μA (typ), which reduces power consumption and improves battery efficiency.
- The LD6806 series also features outstanding ESD robustness of 10 kV (HBM), thermal shutdown, and a current limiter to protect circuits.
- Package options include the LD6806F in a very small DFN1410-6 (SOT886) leadless package with dimensions of only 1.45 x 1.0 x 0.5 mm, or the LD6806TD in a 5-pin SOT753 general-purpose consumer package with standard dimensions of 2.9 x 1.5 x 1.0 mm.
- In addition to these package options, the NXP low-dropout voltage regulator product portfolio also includes high PSRR performance LDOs with 75 dB, such as the LD6805K in an ultra-small lead-free QFN package (SOT1194), with dimensions of only 1.0 x 1.0 mm and a height of 0.55 mm (max).
