Z-Communications Announces Low Cost VCO Provides Wideband Solution for Satellite Communication Systems
Z-Communications SMV5550B-LF
Z-Communications, Inc. is once again displaying its engineering prowess in VCO technology by introducing the SMV5550B-LF. This high performance VCO generates frequencies between 5000 and 6000 MHz, covering the 1000 MHz bandwidth within 0 to 10 V of control. Even though the device covers a broad spectrum of bandwidth, the SMV5550B-LF comes in a compact package covering an area less than .10 sq. inches while exhibiting remarkably good phase noise performance of -80 dBc/Hz, typically, at 10kHz from the carrier.
Z-Communications - SMV5550B-LF
The SMV5550B-LF delivers 3 ± 3 dBm into a 50 W load with a nominal 5 V supply and drawing typically 24 mA. In addition to its low noise performance, this device also exhibits excellent second harmonic suppression of -35 dBc, typically, and provides better than 1.1:1 tuning linearity making it the ideal component for satellite communication systems. Load pulling is furthermore minimized to less than 10 MHz with a return loss of 20 dB in any phase while it pushes less than 20 MHz/V with a 5% change in the nominal supply. A truly spectacular accomplishment by Z-COMM engineers once again!
This low cost performer operates at a temperature range of –40 to 85 degrees Celsius and is packaged in Z-Communications miniature SUB-L surface mount package measuring a mere 0.3" × 0.3" × 0.08".
Performance Specifications
Min
Typ
Max
Units
Oscillation Frequency Range
5000
6000
MHz
Phase Noise @ 10 kHz offset (1 Hz BW)
–80
dBc/Hz
Harmonic Suppression (2nd)
–35
–30
dBc
Tuning Voltage
0
10
Vdc
Tuning Sensitivity (avg.)
135
MHz/V
Power Output
0
3
6
dBm
Load Impedance
50
W
Input Capacitance
50
pF
Pushing
20
MHz/V
Pulling (20. dB Return Loss, Any Phase)
10
MHz
Operating Temperature Range
–40
85
°C
Package Style
SUB-L
rfcafe.com
