MACOM Announces New Wideband Amplifier Covering 30 kHz to 40 GHz for Instrumentation and Communication Applications
MACOM MAAM-011275-DIE
  • Input and output are fully matched at 50 Ω with typical return loss of 13 dB across the band
  • Supports wideband operation from 30 kHz up to 40 GHz with typical gain of 15 dB
  • MACOM’s new wideband amplifier is available to customers today
MACOM Technology Solutions (MACOM) announced a new wideband distributed amplifier with the introduction of the MAAM-011275-DIE.
MACOM - MAAM-011275-DIE
Offered as a bare-die, this amplifier is well suited for use in test and measurement (T&M) and communications equipment with broadband frequency coverage from sub-6 GHz to mmW. The MAAM-011275-DIE amplifier supports wideband operation from 30 kHz up to 40 GHz with typical gain of 15 dB. The input and output are fully matched at 50 Ω with typical return loss of 13 dB across the band.
The MAAM-011275-DIE adds to MACOM’s portfolio of wideband amplifier solutions, and is available to customers today.
Typical part number performance
Parameters Units MAAM-011275-DIE
Gain dB 15
Flatness dB ±0.75
P1dB dBm 21
P3dB dBm 24
OIP3 dBm 33
VDD V 7
IDSQ mA 200
