New MR16 LED Lamp Control Boards to Replace 35W and 50W Halogen Lamps
Infineon
Energy-efficient, low-voltage MR16 LED lamps consume up to 80% less power than halogen lamps and last up to 15 times longer. Infineon's ready-to-use control boards are the ideal solution for driving low-voltage halogen replacement lamps.
Both the 7W and 10W boards operate either with 12V DC or AC supply voltage. Their compact design delivers the right DC output current for the LED load. The solution is compatible with electronic and magnetic ballasts and comes 12along in typicalwith GU5.3 socket pins for instant use in existing lamp designs.
Simplified application diagram
Features
  • Compatible with both electronic and magnetic ballasts in flicker-free operation
  • Utilizing cost effective step-down topology
  • Suitable for 12V AC or 12V DC operation
  • Output designed to operate with 2 or 4 LEDs
  • Preset currents: 7W board: 770mA, 10W board 1020mA, adjustable by resistor
  • Board efficiency up to 93%
  • Overtemperature protection
Applications
  • Low voltage MR16 halogen replacement lamps
infineon-designlink.com
