Best-in-Class Six-Pin GNSS LNA with BGA825L6S
Infineon BGA825L6S
Infineon's BGA825L6S is a best-in-class Low Noise Amplifier (LNA) for Global Navigation Satellite Systems (GNSS). It has a package footprint of just 1.1mm × 0.9mm² and offers an extremely low noise figure as well as excellent linearity, low current and high gain.
Infineon - BGA825L6S
The LNA is also self-shielded to avoid external interference and requires only one external component.
This single-chip LNA comes with integrated biasing, RF choke and output matching, all of which significantly reduce design timeframes and make it a lot easier for system engineers to drop the LNA into a receiver frontend and enhance a wireless system's sensitivity. The LNA also features an on-chip on/off switch which can be easily controlled using a DC level analog to the power supply voltage. On-chip ESD protection of 2kV HBM provides a high level of ESD robustness and eliminates the risk of ESD strikes when the receiver is in use.
Features
  • Best-in-class six-pin GNSS LNA
  • Very small size: 0.99mm²
  • Supports all navigation standards (including GPS, GLONASS, Beidou, Galileo)
  • Only one external SMD required
  • Includes self-shielding
Applications
  • Smartphones and mobile phones
  • GPS, GLONASS, Beidou, Galileo systems
  • PNDs
  • Laptops
  • Digital cameras
infineon-designlink.com
