Avago releas DC to 50 Megabaud Versatile Link Fiber Optic Transmitter
Avago AFBR-1634Z
Avago releas AFBR-1634Z transmitter utilizes a 650 nm LED source with integrated optics and driver IC for efficient coupling into 1 mm Polymer Optical Fiber (POF).
The transmitter input is compatible with TTL logic families. The transmitter operates any type of signal from DC up to 50 MBd at distances up to 50 meters with 1 mm POF.
Avago AFBR-1634Z
The transmitter is a 4-pin device packaged in a vertical Versatile Link housing. Versatile Link components can be interlocked (N-plexed together) to minimize space and to provide dual connections with the duplex connectors. Various simplex and duplex connectors as well as POF cables are available for Versatile Link components.
Features
  • RoHS-compliant
  • Data transmission at signal rates from DC up to 50 MBd
  • Integrated 650 nm LED and driver IC with TTL input logic
  • Up to 50 meters distance with 1mm Plastic Optical Fiber (POF)
  • Operating temperature range of -40° C to +85° C
  • Vertical Package
  • Compatible with Avago’s Versatile Link family of connectors for easy termination of fiber
Applications
  • Industrial control and factory automation
  • Extension of RS-232 and RS-485
  • High voltage isolation
  • Elimination of ground loops
  • Reduces voltage transient susceptibility
avagotech.com
