Reduce Costs and Increase Security with OPTIGA Trust SLS 10ERE
Infineon SLS 10ERE
SLS 10ERE from Infineon is a turnkey authentication product in the OPTIGA™ Trust family. It is a robust cryptographic solution that delivers enhanced protection against aftermarket replacements and helps manufacturers verify the authenticity, integrity and safety of their original products.
Infineon SLS 10ERE
SLS 10ERE is designed for embedded systems that require highly reliable security and authentication features. It protects systems from unauthorized accessories, replacement parts and disposables, easily identifying unauthorized additions and triggering subsequent action. It also uses a data authentication feature to identify unauthorized re-use or re-provisioning of original parts and asymmetric cryptography to significantly reduce system costs while at the same time increasing overall security.
SLS 10ERE – turnkey solution for authentication
Infineon SLS 10ERE
Features
  • Strong asymmetric cryptography with a 163-bit ECC key
  • Turnkey solution including host-side software for easy integration
  • 3.5Kbit user non-volatile memory (NVM)
  • Easy-to-implement single-wire interface
  • Unique asymmetric key pair per chip
  • Session key feature
  • Size-optimized USON-3 package (2 × 3 mm)
Applications
  • Printer cartridges
  • Accessories (earphones, speakers, docking stations, game controllers, chargers)
  • Peripherals (adaptors, etc.)
  • Original replacement parts
  • Diagnostic & medical supply equipment
infineon-designlink.com
