STMicroelectronics announced new three accelerometers
STMicroelectronics LIS3LV02DQ LIS3L02AL LIS3L06AL
STMicroelectronics announced that it has expanded its portfolio of three-axis accelerometers with three new models, embedding world-class performance in ever smaller packages. From ultra-compact analog devices to ‘smart sensors’ with two digital output formats (SPI/I2C), ST’s low-power, high-resolution MEMS accelerometers address different system needs and hardware characteristics in a wide range of low-g applications, from hard-disk drive protection to motion user interfaces.
Accelerometers by ST's
ST’s LIS3LV02DQ is the market’s most advanced 3-axis low-g accelerometer with a standard SPI/I2C digital interface. Its novel features, including adjustable bandwidth and direction detection, mark the transition towards the concept of “smart sensors.”
Adjustable bandwidth provides optimized performance for different frequencies, raising the resolution by eliminating interference from irrelevant frequency areas. In ST’s LIS3LV02DQ, the bandwidth can be flexibly changed with a software command, allowing designers to effectively combine measurements of slow and fast motions, such as tilts and vibrations, in one application.
The embedded feature of direction detection immediately signals threshold crossing along any of the three axes. This information helps quickly understand in which direction the sensor is moving before any data calculations are made. Areas of application include intuitive user interfaces in various computer and consumer applications, such as 3D mice or gaming consoles.
ST’s new analog-output LIS3L02AL/LIS3L06AL sensors are the market’s first devices in slim-and-small plastic LGA (Land Grid Array) packages. Their 5x5x1.5 mm3 dimensions meet the space constraints of the booming small-form-factor applications, including mini disc drives, mobile phones, and other portable electronic devices.
ST’s leadership in MEMS miniaturization goes hand in hand with superior performance parameters. The new accelerometers can measure both tilt and acceleration along all three (x, y, z) axes at a very low noise level and minimized power consumption, which is especially critical in battery-operated portable systems. The LIS3L0xAL devices also offer high temperature stability and tight offset tolerances, and their robust design provides very high immunity to vibration and a shock resistance up to 10,000g.
ST’s new three-axis analog sensor is available in two acceleration ranges, the standard +/- 2g LIS3L02AL for tilt applications, and a dynamically selectable choice of +/-2g and +/-6g in the LIS3L06AL, suited for measuring both static and dynamic accelerations, such as vibrations or rollover motions.
