New Vishay Intertechnology High Voltage Thick Film Chip Resistors Deliver Power to 1.5 W, Increased Design Flexibility
Devices Offer Voltages to 3000 V, Stability of < 0.5% in Variety of Styles, Termination Materials, and Configurations
Vishay Intertechnology introduced a new series of high voltage thick film chip resistors that offer high power ratings up to 1.5 W and working voltages to 3000 V in five compact case sizes ranging from 1206 to 2512. For increased design flexibility, the Vishay Techno CRHP series is available in a variety of styles, termination materials, configurations, and custom sizes.
Vishay - CRHP
The devices announced combine their high power and voltage ratings with outstanding stability of < 0.5%. The resistors offer a wide resistance range from 2 MΩ to 50 GΩ, tolerances down to ±0.5%, and temperature coefficients of ±100 ppm/°C. These specifications make the devices ideal for battery management and voltage monitoring and regulation in power inverters and high voltage power supplies for medical, telecommunications, AMS, industrial, automotive, and consumer applications.
Standard CRHP series resistors feature solder-coated nickel barrier or solder-coated non-magnetic terminations in three-side wraparound or single-termination flip chip configurations. The devices are also available with gold, palladium silver, platinum gold, platinum silver, or platinum palladium gold terminations, and a five-sided wraparound configuration. RoHS-compliant and halogen-free, the resistors are flow-solderable and epoxy- or wire-bondable.
Device Specification Table:
Part # Case size P70 °C
(W)
Max. working voltage
(V)
Resistance range
(Ω)
CRHP1206 1206 0.50 1675 2 M to 8 G
CRHP1210 1210 0.70 1870 4 M to 10 G
CRHP2010 2010 1.0 2000 6 M to 35 G
CRHP2510 2510 1.2 2500 10 M to 40 G
CRHP2512 2512 1.5 3000 10 M to 50 G
Samples of the CRHP series are available now. Production quantities will be available in Q1 2019, with lead times of 13 to 15 weeks.
