New Vishay Intertechnology Thick Film Chip Resistors Deliver High Voltages to 500 V in Compact 0805 and 1206 Case Sizes
Vishay RCV e3 RCV1206 e3 RCV0805 e3
Vishay Intertechnology released a new series of thick film chip resistors designed to meet the demand for high voltages in industrial and medical applications, while saving valuable PCB space. Vishay Draloric RCV e3 devices offer high limiting element voltages of 400 V and 500 V in the compact 0805 and 1206 case sizes, respectively.
Vishay RCV0805 e3
With their high voltages, RCV e3 series resistors can replace multiple standard devices of the same size to save placement cost and board space in power supplies, battery chargers, vacuum tubes, and converters. The RCV0805 e3 and RCV1206 e3 feature operating voltages of 400 V and 500 V, respectively, power ratings of 0.125 W and 0.25 W, insulation voltage > 500 V, and high-temperature operation to +155 °C. The devices offer tolerances of 1 % and 5 %, TCR of ± 100 ppm/K and ± 200 ppm/K, and a resistance range from 100 kΩ to 10 MΩ.
RCV e3 series resistors feature a protective metal glaze layout suitable for high-voltage operation on high-quality ceramic, and pure tin solder contacts on a nickel barrier layer for compatibility with lead (Pb)-free and lead-containing soldering processes. The devices are compliant to RoHS directive 2011/65/EU and halogen-free according to the JEDEC JS709A definition.
Samples and production quantities of the RCV e3 resistors are available now, with lead times of eight weeks for larger orders.
